Polarized HVAC filters
North Carolina
We had a new HVAC system installed a year ago and it had been serviced the first year for free. Now it's my turn to replace the Polarized filter in the air handler. Are they really worth the cost or would I be better off just getting regular "rock catcher" fiberglass filters? Also is it best to have the filter right at the air handler or put it at the cool air intake inside the house?
The polarized filter I took out and put in the last replacement that was left with the system when they installed it, looked ok. I could still see through it even thought it was installed for over 6 months.
Just wondering if the polarized part is really all the hype it is supposed to be. Thanks.
Supposed to be higher efficiency. going to standard fiberglass filter defeats the electro-magnetic charge that the polarized filter has. Up to you to decide if it works well or not. If anyone in your family is sensitive to dust, dander, etc, it probably has value.
Interesting. I didnt know they exist.
Me? IT would bother me if I could still see through it. Also trust that it was always working.
I would go with typical Merv 8 filters and change every 3 months, if they come out clean push it to 4.
I have only seen one "rock catcher" fiberglass filter I liked, used by a home builder. I forgot the brand, I think it was actually branded by the equipment maker (maybe trade or Lennox). It was a true one inch thick filter. The ones in the home improvement stores are very thin. I dare say it may have had a Merv rating on it of 4 or 5 with was unsual.
For almost two decades now I have tried all sorts filters, first 15 years in our much larger home that we sold recently. Everything from 1 inch to Honeywell (and knock offs) 4 and 5 inch thick. The thick ones I would replace every 6 months, maybe at one time every year.
Both homes have two intakes and they go behind the air intake grills. Not at the unit.
Anyway, the cost of the thick filters was getting crazy and I rather replace the one inch every 3 months for less money. Im sure I could go to 4 months. Our new home has two - 14x14xx1 and 25X14X1 Plus one 6 x 6 fresh air intake.
I posted them in here recently. They were well made and bought on Amazon. MOAJ was the brand and now looking them up on Amazon I see they changed the product on me to a higher Merv in my size so I will not re-order. I dont want anything higher than Merv 8 They seem to be changing up their product line. Common with aftermarket brands and why I have used so many different brands.
I almost wish my filter was at the air handler instead of the two air intakes. Then again, getting up into my attic would make that a chore with our new home of 3 years. Since it is at the air handler, cant you use 3inch plus size filters?
If not I would go with what I posted, one inch, change every 3 months. Merv 8
Photos of the actual filters I just change out are the link below. I liked these filters because there was cross bracing on both sides of the filters, well made. But looks like I will go searching again if I cant find my exact size with them in Merv 8
All I can tell you after working apartment maintenance and my parents experience is this Filters are cheap a new HVAC system isn't. The apartment complex where I worked used cheap fiberglass pre-filters and the ducts were coated in dust. Not something I want to breathe in. My parents used 3M 1900 to 2100 filters and the ducts are spotless. Their hvac system lasted 21 years.
Put a rock catcher in the inside the house air intake, and a MERV 10 at the air handler. You won't be needing anything polarized.
