- Joined
- Nov 29, 2009
- Messages
- 7,267
I'm looking at having an hvac system installed in my shop. It's going to be a 5 ton AC/heat pump system and the installer said I need a 50 amp for the air handler and then a 40 amp breaker for the outside condenser unit. I willl clarify in the morning with the installer, but he said I needed to upgrade the wiring in the panel. Is he saying I just need to have room in the panel for a 50 amp breaker, then the 40 amp will be outside in the disconnect for the condenser?
