Please recommend a good WiFi booster
Winnipeg MB CA
I guess the title says it all.
My wife's laptop computer is set up c. 12 m/40' from the modem, and it seems the WiFi could use a bit of help at that range.
Suggestions appreciated. Would prefer to not purchase from Amazon.
Thanks!
Have you considered a mesh system? Due to the location of our DVR and network cable runs we have to place our primary modem on the far end of the top floor of our fairly tall and narrow house. The Peloton in the basement wasn't very happy about that. I was looking at boosters and ended up settling on Telus' Boost system. They swapped out my modem for a Boost compatible one, and I only had to pay $120 for the secondary wireless component they put in the basement. Coverage is much improved now.
what wifi/router do you have now? 40ft doesnt seem bad unless its older home with metal mesh in walls.
I would upgrade the wifi router, possibly to a mesh type system.
Also how fast is your internet.. if you have 1Gbit you will want faster gear than if you have 50mbit connection.
Also for us non-Canadians what store(s) would you prefer to order from.
Costco an option?
Note this isnt directly answering your question because most "boosters" are junk.
Its not a booster, but I recently installed a Google Nest mesh router system in order to improve the WiFi in my house. I got the system with the base unit and two additional routers to fully cover my 4,000 square foot, three story house. I also installed an 8 port, unmanaged switch to provide hard wired connections to certain areas for specific devices. It was easy to set up, has been problem free, and I am really happy with it.
My internet provider is Time Warner, and I run two Asus routers. The master is on the lower lever, and the second (Ai mesh) is on the upper level. It's been flawless.
Kids were complaining about our wifi before the pandemic with modem set up on the main floor. Once they were stuck at home with online schooling, having weak wifi was not good. Ended up buying used three $80 Google mesh pod set up (didn't want to spend a lot in case we didn't like it) with a pod set up in each floor (4000 sq.ft. three floor house) and it's been working well. No more dropped signals and consistent coverage throughout the house. Our mesh is older technology unit, but still effective enough for $80 investment.
I tried the Google mesh system and returned it. Not compatible with Comcast Xfinity.
Any third party router or mesh system is compatible if you make an Ethernet connection to the first mesh point (and ideally also all the other ones too). Once you are running your own wifi, shut down the wifi features of the Comcast modem especially the "xfinitywifi" signal which just clutters up the frequency band. Also you can and usually should buy a third party modem which doesn't have wifi in the first place.
Comcast has their own mesh / extender scheme which I'm surprised they didn't try to rent to you.
They did. It didn't work well. There was one room in the house that needed wireless Xfinity TV...which will only work with the Comcast Xfinity gateway or their mesh system. I opted to put the gateway in the room that needed the wireless cable TV box and installed the wifi extender and a MoCA adapter for the 75" TCL 6 series TV in the basement. Have excellent streaming and wireless signals throughout the house now. The extender works great.
Thanks!
Where's the placement of your router? Unless you have lead lined walls 40ft is nothing for wifi. I pickup my wifi down the street. 5ghz network of course doesn't broadcast as the 2ghz network but something is wrong at 40ft you're having issues.
Thanks!
Any other devices have an issue?
Are we sure it's not her laptop with problems?
What leads you to the conclusion it's a router issue and not an issue with her laptop?
This raises a good question, any cellular or wifi device that's placed on my granite top kitchen island suffers greatly.
The easiest and most painless way to do what you are trying to do would be with a Powerline Ethernet Adapter/Extender with WiFi. TP-Link makes several cost effective kits starting with the AV600 (TL-WPA4220 KIT) for about $60. The only caveat to this setup is that both the transmitter and receiver must be plugged into the same 110v side of the home's 220v power feed (the distance is not important). Not long ago I recommended this to a BITOG member who wanted to use his WiFi devices in his detached garage and couldn't get a good signal from the WiFi router in his house. He took my advice and it has worked out well for him.
If you want to fix this and don't want to have any more similar issues, you need to get mesh network. I picked up Netgear Orbi from Costco few years ago. Before that I tried everything by rolling my own repeaters, routers, bridges etc because damm it, I had wired my house with Ethernet in every room and I was sure I could use that to my advantage. But it never worked to my liking.
Trust me; once you put the mesh network, you will wonder how you lived without it.
Doesn't take a lead lined wall to dramatically reduce range, walls in general have an impact and their composition will determine how much, as well as the number of them.
I'm using a Cisco MR20, but I've used a couple of Aironet AP's, a few Aruba AP's, and, prior to this one, an Aruba Instant AP in my house, which has three finished floors + a basement. AP is on the main floor, as central as I could get it without breaking into the plaster, which would have had it central in the front hall (house is mostly square). AP is on the wall closest to the hall in the living room, which is 13.5'x 23', at the mid-way point about 15" or so from the ceiling.
House is ~100 years old, walls are lath and horsehair plaster.
Reception on the main floor is perfect. Reception on the 2nd floor is good, though with previous AP's 5Ghz fills its shorts in the bathroom, which is ~20ft straight-line distance but through 2 walls and the 1st floor ceiling/2nd floor floor. Previous AP's haven't had smart band switching, but this one does and will push clients to the 2.4Ghz band when reception starts to drop-off, where the signal becomes strong again.
3rd floor (my son's "cave") is good reception directly above the living room (through 2 floors, but no walls) but no 5Ghz and only acceptable 2.4Ghz performance on the south side of the house where he has his consoles setup (PS4 previously, now PS5). His phone works properly too, but is also on 2.4Ghz. Straight line distance this might be 25ft or so (maybe 30) but it's through 2 wall/ceiling combos vs the north side of the space, so at least twice as much plaster.
Through open air, I can pick-up my Wifi almost a block away due to the large windows in my living room and I can use a WiTech (FCA/Stellantis dealer pod) in my driveway, which is about 25ft through an external wall, no problem, despite the unit having a very small antenna.
While it would be a bit unreasonable to average Joe Average home owner do a proper site survey to determine optimal placement of AP's (which assumes the likelihood of more than one) this is what is done in commercial installs and the construction/composition factors have a significant role in the number of devices required, antenna selection...etc. This also applies to very large (higher budget) home installs but is a conversation likely beyond the scope of this thread.
