I have a Toro Super Recycler Mower with a 6 H.P. Briggs Engine, yesterday I noticed the mower was down on power, so I took the spark plug off and cleaned it, it ran a bit better, so I brought the mower in the garage and took the carburetor off, the fuel bowl was clean, I then just sprayed the carburetor with some carb cleaner and sprayed the carb linkages.
Took the mower out and it ran fine, this morning I took the spark plug off and noticed some carbon inside the spark plug hole, maybe what I was looking at was the piston, I went ahead and put 2 cap fulls of MMO into the spark plug hole and pulled the cord a few times and put the spark plug back on. Should I let this piston soak go 24 hours or maybe 48 hours, is there a product that will do a better job than MMO as a Piston Soak.
