- Joined
- Sep 28, 2002
- Messages
- 39,799
Quote:
Quote:
Where's Bill in Utah? He should be here any second now to defend the value of SuperTech filters. Mr $5 oil change. . .
You know, I just spent 20 mins typing up a reply incl FACTS links of photos and such.
I've cut open more filters than you'll EVER use.
Never had a problem.
But who cares. With the way this board is (has) going/gone, I'm wasting my time.
So nevermind.
Everyone *NEEDS* to spend ATLEAST $10 per oil filter to get any filter worth putting on their engine.
And never cut one open because it will never have a problem.
See, I can have the mindset of a lot of BITOG members.
Amazing.
Relax, Bill
You buy based on your need ...however you perceive it.
We've got people who consider 5k an extended drain ...and if they're taking enough time to put the 5k on ...they're right when comparing it to a 3m/3k alternative. They may also want the added benefits of a synth ..whether they need it or not. Whatever insult their engine is enduring, they want it to be less.
If you're using the same filter and it DEVELOPS start up rattle at a certain point in the OCI ..and it bothers you, switch to one with a silicon ADBV. This is NO ASSURANCE that JUST because you have a silicon ADBV that you'll never have startup rattle. It just means that "inherently" the use of a silicon ADBV will last longer than its nitrile counterpart. It too is subject to the occasional in process or supplier defect.
I'm into extended drains. I've used Fram or Fram clones. Every one of them eventually got a startup rattle. Now the startup rattle never really bothered me in terms of concern. It was more in the realm of annoyance. Since I do extended drains, I can get the value out of upper tier filters. Now most can do the same, without the extended drains, if they want to leave the filter on for a couple of OCI's
I'll continue to use ST or AA Total Grips on my daughter's Taurus. Now that she's working and attending college locally, she may do 10k a year in radically mixed usage. 6month OCI's and cheaper filters.
On my rides, due to the extended habit I've acquired, I'll use EaO filters. If I didn't, I'd probably use PureOne ..or wait for a M1 AA sale or something. Wix filters are always a good choice too.
