Picking a low cost floor jack
I posted this once before. (So just cut and pasted)
Bleeding
1. Loosen the fill screw.
2. Turn the handle counter clockwise to open the release valve.
3. Pump the handle up and down quickly several times to purge the air from the system.
4. Tighten the fill screw.
Adding oil
1. Remove the fill screw.
2. Add hydraulic fluid into the fill screw hole slowly until the oil reaches the top of the oil fill hole. NOTE: Do not touch the handle when adding hydraulic oil.
3. Replace the fill screw.
See this website:
http://www.blackhawkparts.com/
Why not fix your old unit? I have an older Hein Werner that I won't ever give up for any import junk. Those old USA jacks were well built and easy and cheap to fix with the proper kit. You Tube is full of info or just Google floor jack repair. OK, they are heavy, clunky, and take lots of strokes to lift, but I can handle that. Quality is quality. When they say 2 ton, you can believe it. Not the over rated [censored] of today.
Check the prices of older USA floor jacks and you will see why knowledgeable users and service garages value them.
Bleeding
Adding oil
Thanks for this. I have a 3.5 ton Larin that creaks once its holding a vehicle up.. perhaps it needs re-bled.
Bleeding
Adding oil
Jacks should not hold up a vehicle - they LIFT a vehicle. Use jack stands.
Bleeding
Adding oil
I'm well aware of that and was in no way suggesting it be used as a jack stand. It is nice to have all the time you need to carefully position jack stands without being concerned with the jack settling. If I'm putting any body part under a car, I use ramps, jack stands, and the jack itself. Overkill on support so as not to get killed under.
