PIAGGIO VESPA PK 125 S AUTOMATICA - Oil
Milano (Italy)
Hi guys, when I have any doubts about the oil I ask here and I'm more sure.
My brother recovered a PIAGGIO VESPA PK 125 S AUTOMATICA. Unfortunately, he does not have the workshop manual and he asked me for help to change the oil on the final drive (the one on the side of the rear wheel).
I removed about half a liter of oil from the drain plug. Obviously it's brown, it stinks.
I wanted to be sure, the oil that should fit is Dexron II?
The only manual I found is this:
https://www.scooterhelp.com/serial/service.pk125.automatica.html
https://www.scooterhelp.com/manuals/pk125.automatica/017.jpg
Because in another Vespa (not automatic) it was written to put an SAE30 oil. Is it plausible that the version with automatic transmission uses a different oil?
Do you have any way to check if what I have found is correct? Thank you
If that is the correct manual, then follow the manual which says Dexron II.
Yes, an automatic vs not automatic transmission would probably use different oil. Follow the correct manual specs.
Not an answer to your question, but it brings back memories of my youth and a Vespa 175GS only then there was only manual transmission.
A lot of FUN !!!
That's right :ROFLMAO: . Not having the original user manual and having found a different oil than what I expected in the one in PDF made me panic o_O
Non sapevo che la Vespa esisteva con il cambio automatico. Che meraviglia! Credo che questo lo sai, ATFII non esiste piu. Se hai un po rimasto dal BMW puoi anche usare quello. E' solo mezzo litro che hai bisogno, vero?
yes. I recovered just under half a liter from the drain plug
Dexron III succeeded Dexron II
