PH6607 cut and post 5k
Prosper, TX
Nothing to see here. I normally run the TG6607 but they were out so I went with the orange can. The pleat spacing stinks, but it held up fine. The blue spec in the second pic is a piece of the Kia filter I also cut. This is from my daughters Sentra running Edge 0w-20 for 5k.
Looks fine, not known for tearing. I would run for a regular factory scheduled OCI. For my gf camry, I will run ph4967 for 5k. For $3.88 it's a great filter.
Does that one have the combo valve?
IDK if it has the 'combo valve'. The ST appears to be a mix of the e-core (plastic inner support) with regular end caps. I'll know for sure when I cut open the one on my daughters Mazda. I think I read on another thread that the $2.97 ST's filter 99% @ 30 microns (I'm not sure if those #'s apply to all model # ST's). Does anybody know the efficiency #'s of the Fram PH6607? Fram says 95% but not at what micron size.
