While changing my oil earlier this week I happened to notice that the AC PF-52 installed earlier by my GM dealer was different from the AC PF-52 filter I purchased at WalMart. The one from the dealer bears p/n 25171377 and is maybe 3/4 inch longer than the one from WalMart which bears p/n 19210286. Looking into the end of both filters there are some differences in construction. Also the label is slightly different in that the dealer supplied filter says "Tighten 3/4 to 1 turn" whereas the one from WM says "Tighten 3/4 turn".
I would have thought all PF-52 filters were the same but now I'm confused. Hoping someone can explain why these filters have different part numbers and if this is anything I should be concerned about. Knowing this, I plan to check filters at some othere auto parts houses to see what number they carry.
