You put a 7/16" socket on your cordless drill and have 20 PSI in 10 seconds. Might not want to dry start a $50K race engine after it sat a few months.
The pump is a "Roots" type design. Plumbing the remote filter mount has to include an extra line tapped below oil level on the pan for wet sump, or to the tank on dry sump systems. They make them for large diesel type filters (1-1/2" stud) and for common Ford or Chevy filters (PH8A or PH13 or equivalent)
The mount without a bracket is about $380. They make brackets for tubing or firewall mounting.
http://www.lsxtv.com/tech-stories/other-...r-filter-mount/
