Permatex Spray Sealant
SE British Columbia, Canada
Has anyone tried the Permatex Spray Sealant? It’s for low pressure applications like pan gaskets, or high side of diffs, anywhere where slashing oil can leak out at a bad gasket. I wouldn’t put it on a hose but it might help on those pesky leaks where pans bolt to rails.
I used this this month.
I had an oil pan weep (involved job to replace on my car) - I spent a night cleaning the entire perimeter of gasket area. Warmed the engine up, put a shop vac on oil fill plug to pull a vacuum on the crankcase to in hopes suck any of the sealant into any voids in the gasket.
I applied 6 coats with 1 min wait time in between. Let cool off and sit for 2hrs, then did 6 more coats. (Overkill likely..)
Comes out like water and then stars to thicken until it drys like hard hard rubber.
Over 1000km driven since then, not even a visible oil stain under the sealant, 100% leak free.
One pics of stains before, a close up of one area after the 1000km, dry and can see the rubberized stuff in that gap.
Has my vote, just follow the prep stuff correctly.
