This isn't rocket surgery. Give it a good nnnnnngghhhhhh with one hand and move on with your life. This seems like either a freak occurrence with the gasket or Murphy's Law.
Some good points. But IMO you’re giving OEM filters way too much credit. More have flat gaskets vs P style. Many are made by some of the worst offenders for QC. That said most of the made in Japan OEM filters have great QC but low efficiency. Anything OEM made by First Brands or M+H are a hard pass.Post-Mortem & Lessons Learned
At the time of the failure the last oil change (done by me) was 3400 miles and nearly 4 months. No prior leaks, drips, smells or warnings. Oil level had been normal at last check. Vehicle driven normally, no track use.
In my haste and failing to consider the oil filter as the cause I had the car towed to my dealership fearing catastrophic engine failure. (warranty concerns).
Dealership determined the failure was do to the oil filter gasket. Specifically - *The oil filter had lost its seal. *No evidence of drain plug failure. *No evidence of filter loosening. *Failure occurred ay the filter-to-housing interface. *Tech stated the gasket "did not seat properly.
How can a gasket fail after 3000 miles with no warning? I learned the hard way a marginally sealed flat gasket can survive for months and then fail instantly under the right conditions - especially a cold start. * oil is thick *relief valve may not open immediately *oil pump pressure spikes are highest *turbo engines amplify this due to oiling demands This is the exact moment a weak seal is most likely to fail.
Something I never really thought about and the real lesson learned - Gasket Design Matters
Molded / profiled design "P-style" or bead-style gasket. (As with OEM Honda Oil Filter Gasket)
Designed to:
*Self center
*Resist extrusion
*Tolerate minor surface or torque variance
*Pressure actually helps the gasket seal tighter
*Dynamic seal, not just a compressive washer
Aftermarket Flat Gasket (What Was on the Car)
*Simple flat rubber ring.
*Seal fine when new but can compress and "relax" over time.
*Are more vulnerable to cold-flow, compression set & extrusion under high pressure.
*Less margin for error.
Probable Failure Mode
Based on the evidence and failure pattern:
1. Gasket initially sealed well enough
2. Over Time normal heat cycles caused compression set
3. Clamp load reduced slightly (not due to loosening)
4. Cold start pressure spike caused gasket extrusion
5. Seal was instantly lost
6. Oil dumped rapidly
This could explain *No prior seepage *No warning signs & Sudden, total oil loss.
Damage considerations
I'm happy to report there are no signs of damage to the engine of turbo. Luckily within seconds of seeing the "Low Oil Pressure Warning" I was able to shut the engine down with seconds. Had I for whatever reason, chosen to go back into the house to let the car warm up we could be having a much different conversation and outcome.
Takeaways and Final Thoughts
*Gasket design matters
*A gasket can fail months later
*No leaks for 3000 miles does not guarantee long-term sealing integrity.
OEM filters aren't just about brand loyalty - the gasket geometry is engineered for the application .
This event has changed my view on oil filter selection. While flat gaskets can and do work, their margin is smaller. Does this mean that I will cease using the other 11 Pentius UXFL filters from the case I just bought? No, but you bet I will be laser-focused on proper tightening and seal integrity.
Hopefully this helps someone else avoid the same experience.
Not to mention, OEM filters are both flat or P design seemingly arbitrarily.Some good points. But IMO you’re giving OEM filters way too much credit. More have flat gaskets vs P style. Many are made by some of the worst offenders for QC. That said most of the made in Japan OEM filters have great QC but low efficiency. Anything OEM made by First Brands or M+H are a hard pass.
I don't agree with the supposed attributes of P style vs flat. Either design can take a set, either can fail months later, both resist extrusion, both are self centering.Post-Mortem & Lessons Learned
Designed to:
*Self center
*Resist extrusion
Yep, get into the habit of marking the dome of the filter with a Sharpie or a piece of tape once the gasket makes initial contact, then make sure it's turned 3/4+ turn after that. Use a proper filter end cap tool if required to get the proper turn amount.This event has changed my view on oil filter selection. While flat gaskets can and do work, their margin is smaller. Does this mean that I will cease using the other 11 Pentius UXFL filters from the case I just bought? No, but you bet I will be laser-focused on proper tightening and seal integrity.
Too add, as discussed in this thread about P-style gaskets, when those style of filters are installed correctly the base of the can is basically touching the filter seat, so there isn't an air gap for the P gasket to blow out of. If a filter with a flat gasket isn't tightened down enough, there is less compression of the seal, and there is a larger air gap for it to blow out of. This is why I always go by amount the filter turns after the base gasket first makes contact. If I can't get to 3/4+ turn by hand I have many filter end cap wenches to use with a ratchet to get the required tightness.The "P style when compressed is the same shape as the flat. It just has to compress the smaller contact area (the raised rib) to get there. This is because the mount flange is the last side of the gland and determines the final shape of the sealing cavity.
Well, I was the primary culprit in the SAE 40 camp, a couple were amenable to my points.While 5W-30 should be fine in this application, even in Ohio. It's clear that a cold start pressure spike contributed to the problem, otherwise the oil would have puked during the last normal run, not on a cold start.
It's stuff like this that makes me question the "thickies" we have around here. Another recent thread had several of the members here recommending straight 40 weight in a Type R, even when the owner lived in an area where the temp is known to get down to 40F in the winter. Using thick oil on a cold start will surely blast open the pressure relief valve straight away, if the gasket doesn't blow first.
That said, it's likely that some issue with the filter contributed, or likely, is the root cause. I wouldn't be afraid of the filters, though. Tons of people using them, and this is the first time I've ever heard of a gasket failure. Maybe mark the filter next time, and make sure you get a full turn after gasket contact? That's what I'll do anyway, and I'm using those same filters.
I doubt the failure was related to compression set. Silicone is very resistant to compression set, especially when operated far below its temperature limit, and at relatively low squeeze (which was probably the case due to under-tightening).Based on the evidence and failure pattern:
You probably won't be able to get a full turn with a Pentius XL. I measured how much the gasket sticks out from the groove on a PLXL3593A, and it was only around 1.2 mm, whereas the thread pitch is 1.5 mm. That would mean the filter would bottom out at only 1.2/1.5 = 0.8 turns. My measurement was pretty rough, so this isn't very exact, but the gasket certainly sticks out by less than 1.5 mm.Maybe mark the filter next time, and make sure you get a full turn after gasket contact? That's what I'll do anyway, and I'm using those same filters.
Think is was mentioned by someone before, that on a cold start-up the pressure spike could be much higher than what the oil pump's pressure regulator would normally control to. All it would take is a short, high pressure spike to dislodge a gasket on a filter that's not tight enough.The high oil pressure on the cold start was certainly a factor, not only due to the pressure on the seal, but also because the filter canister could start to deform from the pressure which would tend to increase the clearance gap. The PXL filters seem to be built like tanks though, so I doubt this would be a huge factor at <150 psi, but I don't know what aspects of the filter construction relate to this.
Funnily enough, this video just popped up on my Youtube recommended list:
TLDW - for a P style gasket, turn the filter until it touches the engine.
And what has it always been?The man is giving wrong advice, the recommendation isn’t to tighten to torque stop. It’s the same as it always has been.
