Pentius PLXL1495P disappointment
PHX, AZ
Got a case of these recently and took a look inside. Not good...a bunch of the perforations were not completely knocked out of the center tube. I was able to dislodge them easily using a pencil, I would assume oil flow would have dislodged them as well.
Looks like one of the new China factory models. .. Very bad and you should try to get some feedback from them if you can.
  • Like
Reactions: GW.
Send them back for a refund. Not good at all. The case I got seem fine. Cut open a couple and look very good. Stuff happens, but that should have never made it out of the factory.
this is the new China factory they recently started to use... your case was Korea.. right ?
