Pentius PLXL 7317 C&P 5k miles
GW.
2016 Acura RDX 132k miles. 5154 mile oci.
Out: Mobil 1 ESP 0w-30
Off: Pentius PLXL 7317
In: Mobil 1 ESP 0w-30
On: Carquest Premium 84356
Pentius looks good. Got me a case of those recently. Gotta pass on the Max-Life ATF. Hope you don't mess up your AT with that stuff.
Been using it for years. This Acura had a TSB done to it(reprogram) when new for the trans overheating the factory DW1. It always had a shudder. At 30k I switched to maxlife and never had a problem again(132k miles).
. @Glenda W.
I was wondering if this is the only factory that uses the internal metal crimp .
Have you seen that anywhere else ?
  • Like
Reactions: GW.
Max life atf is generally well reguarded in Toyota and Nissan land. My wife's Nissan has been running it for 70,000 miles without issue.
Max Life ATF jacked up my old Nissan Sentra F04 transmission. It never shifted right again. Shift flare, late upshifts out of low gears when cold, stuff like that.
