My rental 300 was exactly like your Charger: it almost never rose above 2,000 rpm (unless I caned it) and hot idle was never below about 28 psi. I'm not sure why they maintain that type of oil pressure at idle. I realize minimum is lower, but it's significantly lower. The Northstar engines ran much closer to the minimum spec, even when new.
With the electronically-controlled oil pump, they should be able to account for wear-related increases in clearance and maintain the required oil pressure. If minimum spec is 5 psi, I don't see why they'd run closer to 30 psi, especially when they can control it with programming.
There must be a reason; I just don't know what it is. Maybe it does relate to camshaft phasing, as supton suggested above.
