Motor Oil 201
Sarasota, Florida
Motor Oil 201
Chapter 10, The graduate.
I am going to bring up the constant flow pump concept. First, it goes back to the principal that doubling the pressure of the same weight oil does not exactly double the flow but it is close. Also doubling the RPM for the same reason does not exactly double the flow but again it is close.
This shows the problem best:
(A) For a 30 wt oil at operating temperature:
RPM....Pressure..Flow
1,000......20 PSI....1
2,000......40 PSI....2
4,000......80 PSI....4
8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5
(B) For a 30 wt oil at operating temperature
and a higher output oil pump:
1,000......30 PSI....1.5
2,000......60 PSI....3
4,000....120 PSI....6 The maximum flow because of the oil pop off valve at 90 PSI will be 5
8,000... 240 PSI....12
If we stick with the same weight oil and increase the oil pump output we will increase the pressure and the oil flow too. If we double the oil pump output we will double the pressure and we will double the oil flow.
(C) For a 40 wt oil at operating temperature:
The oil is thicker, has more internal resistance and therefore requires more pressure to get the same flow. Compare this with (A):
2,000......60 PSI....2
4,000....120 PSI....4 The maximum flow because of the oil pop off valve at 90 PSI will be 3
8,000....240 PSI....8
(D) For a 40 wt oil at operating temperature
1,000......45 PSI....1.5
2,000......90 PSI....3 The maximum flow because of the oil pop off valve at 90 PSI will be 3
4,000....180 PSI....6
8,000... 360 PSI....12
The situations (A) and (C) are close to real life, assuming no loss in the system. This is what happens when you change the 30 weight oil to a 40 weight oil in your car:
At 6,000 RPM the maximum rate of flow has been reached with the thinner oil (A). When you go to 7, 8 or 9,000 RPM you do not get any more flow. You only get a maximum rate of 5. The internal forces on the bearings increase but there is no additional flow of oil.
With the thicker oil you reach maximum flow at 3,000 RPM (C). Worse yet is that the maximum flow is now only 3. As we increase RPM to 4, 5, 6, 7, 8, 9,000 RPM we get no additional pressure and no additional flow, no increase in lubrication.
Next let us look at a 20 weight oil at operating temperature. We get the same flow out of our constant volume pump but the thinner oil requires less pressure to move through the system. This even goes along with the rule that we should use an oil that gives us 10 PSI per 1,000 RPM:
(D) RPM....Pressure..Flow
1,000......10 PSI....1
2,000......20 PSI....2
4,000......40 PSI....4
8,000.. ...80 PSI....8
The maximum flow rate has not been reached. If the engine went to 9,000 RPM then the flow would be 9 at 90 PSI, our maximum pressure at pop off. The engine now has 3 times the flow rate as with the 40 weight oil at full RPM. The nozzles at the bottom of each cylinder are spraying 3 times the amount of oil lubricating and cooling this section. Everything runs cooler and the separation forces in the bearings are 3 times higher.
For engines that redline at 5,000 RPM they usually pop off the oil pressure at 50 to 60 PSI. For engines that go to 8-9,000 RPM the pressures max out at 90-100 PSI. You can now see that you can only get the maximum flow rate if you follow the 10 PSI / 1,000 RPM rule.
The winner: 0W-20 weight oil for my Maranello. I said earlier that I could use a 10 weight oil. I actually only run with 185 F oil temperature around town and the pressures are similar to the 40 weight oil example in (C) above. This is why I also said that in the racetrack condition, with hotter, thinner (0W-20) oil I may actually get the optimal results as in (D) above.
Now let us go back to the Ferrari recommended parameters in my 575 Maranello manual. It calls for 75 PSI at 6,000 RPM. The pop off pressure has not been reached. As we now increase the RPM we still get an increase in flow rate. This is what we need and this is exactly what they are recommending. We get our maximum flow at the maximum system pressure, at about the maximum engine RPM of 7,700. There is no bypassing of the oil. All oil pumped goes through the system. There is no wasted BHP pumping oil past the bypass valve back to the oil tank. It is the perfect system.
Finally I will compare a single, 30 weight oil, at normal (212 F) and at racetrack (302 F) temperatures:
(A) For a 30 wt oil at normal (212 F) operating temperature:
(E) For a 30 wt oil at elevated (302 F) operating temperature. The oil is thinner at 302 F. It requires less pressure to get the same flow:
8,000......80 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 9
The hotter (302 F) 30 weight oil is thinner than the cooler (212 F) 30 weight oil. It has the same flow rate in the constant volume oil pump but at a lower pressure than the oil at normal operating temperature. This allows for a doubling of the flow rate at peak RPM. The thinning of oil at higher temperatures is a benefit. You get more flow, more cooling and more lubrication.
The 30 weight oil at 302 F has the exact same flow rate and pressures as the 20 weight oil at 212 F. See (D) above. Therefore, use the 20 weight for around town driving and the 30 weight on the hot track. You get maximum flow at each situation.
For YOUR engine, substitute the actual flow at 1,000 RPM. If your engine puts out 1.5 liters/min. at 1,000 RPM it would put out 3 liters/min. at 2,000 RPM and 6 liters/min. at 4,000 RPM and so on. The maximum flow in (A) would be 7.5 liters/min. In situations (D) and (E) you would get a maximum of 13.5 liters/min.
Conclusions:
The reason that multigrade oils were developed in the first place was to address the problem of oil thickening after engine shutdown. Over the years we have been able to reduce the amount of thickening that occurs. Never-the-less there is no oil that does not thicken after you turn your engine off. This is why we have to warm up our engines before revving them up. Engine designers always pick the recommended oil based on a hot engine and hot oil. There is no issue with oil thinning as they are both matched when hot. The problem is oil thickening when the engine cools.
Cold engine showing very high pressures because of the thickened oil at startup:
For a 40 wt oil at 75 F at startup:
1,000......60 PSI....1
2,000....120 PSI....2 The maximum flow because of the oil pop off valve at 90 PSI will be 1.5
4,000....240 PSI....4
8,000....480 PSI....8
At 1,500 RPM you reach the maximum oil flow rate and if you run to 8,000 RPM it is the same rate. The flow cannot increase and it is insufficient. This is why we must wait until our oil temperature comes up to 212 F or higher. The maximum flow rate in this case will then double, up to 3. To get even more flow in our test engine you need to use a lower viscosity grade.
If you have absorbed and digested the information here you should be able to pick out the proper operating oil weight for your car, be it a 30, 40, 50 or even 20 weight oil. I have always used oils that were a grade thinner than recommended even though many use a grade thicker than recommended. I showed evidence that the starting grade should always be 0 or 5 (0W-XX or 5W-XX for thicker oils). If you want the best protection and highest output from your motor use a synthetic based oil. The actual brand is not as critical as the viscosity. The rating must be SL or the upcoming SM rating. Change your oil every 3 - 5,000 miles and at least every spring.
Final examination to follow later.
THE END
Bzzzzt! At higher speeds the journal bearings pass more oil. Since the bearings are the main resistance in the system, oil flow is effected by how much oil the bearings allow to flow through them.
Another effect is the higher centrifugal forces in the oil passages to the rod big end journals. That raises the pressure to the big end journals and inreases the flow rate to them.
I'll let someone else point out some of your other errors.
quote:
Dr. Haas,
I've been reading some of your work, and in theory, it all sounds good.
Do you have any analysis reports on your engine though that would support your statements?
Oil analysis for 2003 Ferrari 575 Maranello and 2004 Ford Expedition:
The Ferrari was delivered with Shell Helix Ultra 5w30. At 775 miles on 23 May 2003 the oil was changed to 0w30 Mobil 1. At 2,250 miles on 14 November 2003 the oil was changed to 0W-20 Mobil 1. With 5,300 miles on the car, and 3,000 mile on this fill of 0W-20 I sent in a sample for analysis. The original oil tested was from a left over bottle from the original Mobil 1 oil cases. So it is of the same age as the oil in the engine. No additional oil was added to the car.
The Ford is a few months old. I changed the original oil after 1,200 miles and later took this sample of Pennzoil Multigrade (regular oil) 5W-20 and sent this in for analysis as well. This fill had 1,000 miles on it (total miles on car now - 2,200).
__________New __________Ferrari_______Ford____
______0W-20 Mobil 1 ___With 3,000 Mi __Expedition, 1,000 Mi on the oil
Iron__________ Chromium _____ Nickel ________ Aluminum ______3__________10___________5
lead __________ Copper ________ Tin ___________ Silver ________ Titanium ______ Silicon ________4___________10__________86
Boron ________247_________220_________101
Sodium _______15__________15__________4
Potassium ____ Molybdenum __ 164_________141_________437
Phosphorus __1375________ 1353________1306
Zinc ________ 1328________1313________1281
Calcium _____ 3456________3143________2340
Barium ______ Magnesium ____53_________154_________14
Antimony _____ Vanadium _____ Fuel %Vol _____0__________3.5__________1.5
Abs Oxid ______?__________48__________3
Abs Nitr _______?__________13__________4
Wtr %vol ______0_________ Vis CS 100C ___9.0________8.1 _________7.3
SAE Grade ____20_________20 __________20
Gly test ______NEG_______NEG _________NEG
TBN _________9.87_______not done_____not done
Everything was well within limits for each car.
I tested my oil using this company: youroil.net
Go to this page and download this Excel file to see other peoples results:
members.rennlist.com/oil/
Here is a description of tests:
http://members.rennlist.com/oil/element_analysis_description.htm
I did some analysis of the Excel data on 144 automotive oil samples tested. This is as far as I can tell:
The average car had 3,750 miles on the oil fill when tested. Most tests were of oil having 2,000 to 5,000 miles on the oil. Range = 87 miles to 16,506, the most was in a 1983 Mercedes 300 TD with over 200,000 miles on it. They used Mobil 1 15w50 and it tested normal.
70 tests were of 50 weight oil. Most were Mobil 1 15w50, second was Castrol GTX 20W-50, third was Castrol Syntec 5W-50.
17 tests were of 40 weight oil. Most were Mobil 1 0W-40.
26 tests were of 30 weight oil. Most were Mobil 1 10w30 then 5w30.
3 tests were 5W-20 Ford oil in a single MY 2000 Lincoln LS. The first test that was sent in had slightly elevated Al and Si but the next two tests were normal. All samples had around 4,000 miles on them. The total car mileage was over 60,000 miles.
Other tests were not of engine oil (transmission, gear) or were not able to be determined.
Of the 40 and 50 weight oils none were tested thicker than the original grade but many that failed multiple tests were thinner. The reason was fuel dilution. Normal is up to 5 % but 6 to 8 will decrease your grade by one and 9 to 11 % or more will decrease the viscosity grade by 2 (a 50 weight oil will be thinned to a 30 weight oil).
Of the 20 and 30 weight oils that failed tests about a third thickened to the next higher viscosity grade. Only one thinned secondary to fuel dilution.
3 of the vehicles tested had over 200,000 miles.
16 of the vehicles had between 150,000 and 200,000 miles.
7 vehicles had between 90,000 and 140,000 miles.
24 vehicles had between 40,000 and 80,000 miles.
The remainder of vehicles had less than 40,000 miles on the clock.
aehaas
[ January 28, 2005, 02:59 AM: Message edited by: rugerman1 ]
Seems intuitive. At the same pressure, I can flow more Vodka into my White Russian than I can Kaluha.
