Hey guys
So I changed the oil in my charger yesterday. Last night I was driving into the city(35 miles each way) I wanted to see if there was any pressure and temp differences because I used 5 litres of liqui-moly 0w-40,a quart of pennzoil 0w-20 and a can of cera-tec.
The oil temp previously on a steady highway drive is always 213f,always,regardless of ambient temps outside. I set cruise at 70mph.
Oil pressure at that speed is always 49psi.
Last night oil temp stabilized at 202f,oil pressure was 51psi. I can understand the psi change because the oil is slightly thicker however the oil temp being 10f cooler kinda baffles me.
I'm not concerned about any engine damage or anything I just found it odd that oil temps decreased.
Hot oil pressure with Mobil 1 5w-20 at idle was 19-20psi,now its 21-22 which I don't see as a big deal and pressure at 70mph with cruise on also increased slightly to 51 psi from 49.
Anyone have a theory as to why my oil temps are lower.
Thanks
I expected more of a oil pressure increase going to a 40 grade from a 20 but my gauges show its nominal.
Thanks
