Penrite ENVIRO+ 0W-16 (Full Syn) soon
western australia
Hi
Penrite are about to release their version of the 0W-16 see product data below.
For your info. I will not be using it.
The timing of release not mentioned.
The PDF states it is proposed to be used in vehicles designed for this viscosity only.
http://www.penriteoil.com.au/pis_pdfs/ENVIRO+HYBRID 0W-16 JANUARY 2015.pdf
ENVIRO+ HYBRID 0W-16 can be used where fuel economy oils are specified such as in Toyota Prius, Honda Civic and Lexus ES3000h.
ENVIRO+ HYBRID 0W-16 is NOT for use in vehicles not specifically designed to run on SAE 0W-16 engine oils. It cannot be used in diesel engined vehicles or in motorcycles.
Industry Specifications
API SN
Typical Data
Density at 15oC, kg/L 0.848
Viscosity, Kinematic, cSt
at 40oC 39
at 100oC 7.6
Viscosity Index 168
HT/HS Viscosity at 150oC 2.45
Cold Cranking Viscosity, cP -35 oC 4367
Zinc, Mass % 0.094
Phosphorus, Mass % 0.077
Sulphated Ash, mass % 0.9
Base Number 7.9
Given the reasoning that the watergrade oil-camp spews, will anyone be running this in their 20 grade spec car? WHaT HARM Could IT CAUSE?
This KV100 is in the monograde 20 margin but the HTHS is low.
Good to see these new oils coming out.
I dont think I'll be running this grade unless it gets specced for my car, I'm happy with my "watergrade" Mazda oil..
I see you looked for high moly to compensate for your 20 grade? Maybe you are more afraid than you'ld like to admit
That moly is "DIRTY" btw. I am in the ZERO-moly camp THIS week
Hey my skirts are factory molycoated. My Pistons too
See that HONDA pcx-004 filter on my Nissan - that's WAY MORE important than oil choice, Im learning - and it needn't be.
