Pennzoil Ultra Platinum
East Coast
Doing a little reading on this oil & found the 10w30 has half the NOACK value of all the rest of the oils....how is it possible ? If using the same base stock (Pure Plus Technology) is the additive pack that different that it lowers the volitility of the oil that much ? Just trying to understand how the 10w30 has a value of 5.7 NOACK & the others range from 11-13 NOACK. Would the 10w30 be a viable option to replace running 5w30 in a state that rarely sees temps below 15-20 degrees in the winter ? Just thinking the lower NOACK would help with valve deposits in my direct injection engine, or is my thinking wrong.
Your thinking sounds solid. Same thing I did. The possible benefits of better volatility outweighed the possible benefits of a better oil for very low temperatures that I'll never see. The Pennzoil Platinum has an even lower Noack listed.
You're likely right. Some argue that NOACK matters little, but everybody wants zero NOACK.
A strategy for colder sates is 10w30 in the warmer 6 months, 0w30 for the colder months.
Lower viscosity spread requires fewer/no VIIs. Fewer VIIs = more shear stability, hence lower Noack.
Thats a non sequitur. Shear stability is just what happens to VIIs to break them up. NOACK is a different set of physics that involves the polymer additives dispersed in the base oil, and the greater amount of VII in non-10w-30 oils does trigger greater boil-off with current technology.
I can't answer any of these question all I can say is I use that there 10w30 oil you speak of. It's great. It's the stuff dreams are made of. It added 100 unicorns to my dyno numbers.
Originally Posted By: Nate1979
Are you sure they use the same exact base stock composition?
I can't say for sure, but they are both 30 grade oils, both are Pennzoil Ultra Platinum that according to Pennzoil uses the Natural Gas Pure Plus Technology, so I can't see why the base stock would be any different between them. I'm just thinking add packs are different to get the 5w & 10w ratings.
Not only Pennzoil Ultra Platinum 10W30 has lower NOACK than its 5W30 and other grades, other brands are the same. Of all types(dino/syn)/grades 10W30 seems to have lowest NOACK.
I've noticed that also, more investigation as to why this is would be great. I'm wondering if it's just the amount of research that's been put into 10w30 oils because that grade has been around for what seems forever vs other "boutique" grades such as your 0w & 5w grades. I'm sure plenty of research has been done on them also, but to have NOACK values reaching 13.5 for some is crazy. The old Pennzoil Ultra 5w30 had a NOACK of like 6.9 I believe, the NEW Pennzoil Ultra Platinum 5w30 is 11.5, it just doesn't make sense to me why that is.
I think 10w30s with a very low Noack are simply a result of blending a 10w30 with the basestocks they have available for the lowest cost. They aren't going to put special effort or money into a legacy grade. As long as it makes the certification they're seeking Noack is likely an afterthought anyway.
I thought seasonal switches were precluded by the proliferation of multigrades. If you really want a low Noack shear stable oil and insist on changing viscosity seasonally, just stick with SAE 30 for the summer. Personally, if I can't rely on an oil year round, I have little interest in purchasing it.
Hatt: I say you're right on the money. No one in any of the majors is expending a huge amount of man hours or ingredients or money to make a wonderful 10w30 that no one in North America specifies anyhow. They're all looking at making an SN/GF-5 lube, without even ACEA specifications, much less builder approvals, so who really cares? Up here, it's very, very difficult to even buy a 10w30 synthetic at Canadian Tire.
I doubt that, as adding VI polymer adds viscosity to the oil at any temperature. So to create a 0w30 you have to start with a thinner base oil mix than to create a 5w30 or 10w30
