Doomed? I can see how bad valve stem seals lead to a high rate of oil consumption, but I as long as you don't let the crankcase run dry I don't see how leaky valve stem seals make the pre-96 4.6s doomed.quote:
Originally posted by ekpolk:
Ummmmmm . . . I don't think this story ends so cleanly. I'm assuming that since rbraughn said he driving a "supercrew" truck with a warranty, it's probably relatively new and not a 4.6L. If it is a 4.6, then he needs to figure out whether or not his engine has Ford's infamous self-destructing valve stem seals. Unlike Toyota's "sludge maker", which only makes sludge if you don't take proper care of it, Ford engines with the bad stem seals are pretty much doomed, regardless of how much care is lavished upon them. Now that said, I'm really not trying to start a Toyota vs. Ford slugfestquote:
Originally posted by mracer:
rbraughn, I don't think you should be so worried about Ford screwing you over for several reasons. Remember, this is not a Toyota or Dodge sludge maker engine you've got.
1. If you run ANY decent oil and filter and change it every 3000-5000 miles, you WILL NOT have an engine failure during the warranty period caused by the oil with Ford's 5.4L or 4.6L V-8's . END of Story.
, but this does further illustrate why owners need to be careful not to give the mfr's a reason to try a warranty denial. Yes, Ford would have to prove that the improper oil caused the problem, and the owner would probably win if he fought, but who wants to be tied up in this sort of battle for 1-2 years?
