Originally Posted By: Trav
EXL has iVTEC and uses a spool valve on the rear head (drivers side). When long OCI are done on these engines these tend to fail around this mileage, 8K is 4K can be too long with this engine even on synthetic.
You positively 100% have a deposit issue in this engine running conventional oil, how severe it is depends on how much time it spent in eco mode.
The worst thing you can do is leave it alone, it can eventually cover the pick up and starve the engine or the spool valve can get filled with junk and prevent 6 cyl operation leaving you with a CEL and an engine trying to run on 3 cyl.
This will tear the $600 electric hydro rear mount (not inc labor) up quickly and light up the dash like a Christmas tree.
The OLM on this engine is absolutely useless, the geniuses at Honda didn't take into account the intense heat generated by the front cylinders during eco mode, it overheats and tears the oil up.
The first thing to clog is the tiny undersized PCV valve and passages under the valve cover then it progresses quickly from there. Crankcase pressure increases and leaks occur, they are not usually permanent if you relieve the pressure.
The rear main seal area of the crank probably has a lot of varnish on it, as it cleans it will leak, it will also subside eventually.
You need to assess the deposit situation first before taking any steps to correct it, don't mess around with High Mileage oils, it does not address this situation, the seals don't need a seal sweller.
Start by removing the front valve cover (looking down the hole wont tell you much), clean the passages under the cover and change the PCV valve. Depending on what you find will dictate the next steps.
I have found a few different ways to address the problem once its severity has been identified, there is a way to clean the pan, pick up and passages without tearing too much apart using this tool and a solvent.
The procedure is my own and must be followed to prevent damage but it works well and is safe. You must clean the front valve cover off the engine to insure good flow to the PCV.
flush tool
I always knew there was a reason I didn't like that little green Eco button in my civic
