From the MSDS, which aren’t perfect but give some idea what the base oils areI'm surprised you entered the Mobil 1 Advanced Fuel Economy oils and omitted the EP oils, as having high GTL content. I would have rated them..... EP - ESP - with Mobil 1 Advanced Fuel Economy having a lowered amount of GTL.
0w20 EP: 50-75% Grp3, 10-25% PAO
5w20 EP: 25-50% GTL
5w30 EP: 10-25% Grp3
They also all have a touch <3% of group 2 in there.
This is also assuming the following interpretation is correct.
Severely hydrotreated heavy paraffinic distillate = Group 3, solvent dewaxed heavy paraffinic distillate = Group 2, 1-decene homopolymer hydrogenated = PAO, distillates heavy c18-50 branched cyclic and linear = GTL
Compare that to 0w20 x2 ESP which lists 50-75% GTL, 10-25% PAO, plus some Ester because the ESP line shows high baseline oxidation.
The ESP and Mobil 1 Advanced Fuel Economy oils all show GTL in their MSDS, as do the EP High Milage oils and Supercar. Some of the Euro FS oils too.
I’ve started using 0w30 ESP as my goto oil to put in everything because a GTL/PAO/Ester blend for under $30 a 5 quart jug is hard to beat.
