Pennzoil Platinum - Made from or with NG?
I'm surprised you entered the Mobil 1 Advanced Fuel Economy oils and omitted the EP oils, as having high GTL content. I would have rated them..... EP - ESP - with Mobil 1 Advanced Fuel Economy having a lowered amount of GTL.
From the MSDS, which aren’t perfect but give some idea what the base oils are
0w20 EP: 50-75% Grp3, 10-25% PAO
5w20 EP: 25-50% GTL
5w30 EP: 10-25% Grp3
They also all have a touch <3% of group 2 in there.
This is also assuming the following interpretation is correct.
Severely hydrotreated heavy paraffinic distillate = Group 3, solvent dewaxed heavy paraffinic distillate = Group 2, 1-decene homopolymer hydrogenated = PAO, distillates heavy c18-50 branched cyclic and linear = GTL
Compare that to 0w20 x2 ESP which lists 50-75% GTL, 10-25% PAO, plus some Ester because the ESP line shows high baseline oxidation.
The ESP and Mobil 1 Advanced Fuel Economy oils all show GTL in their MSDS, as do the EP High Milage oils and Supercar. Some of the Euro FS oils too.
I’ve started using 0w30 ESP as my goto oil to put in everything because a GTL/PAO/Ester blend for under $30 a 5 quart jug is hard to beat.
Actually, a lot of keen DIY oil guys have seen additives at the bottom of some PP containers. I saw it with the euro 0W40 but I would shake the bottle to get it back into suspension.
I've seen it in my PP plat / ultra plat bottles. Clumps, that didn't disperse. I just dumped them into the engine. I assume heat and 6,500 RPM will re-disperse it!
Pretty sure 100% GTL would be terrible for additive solvency, like a majority PAO oil you’d want some Ester or Group 2 blended in.
Valvoline Extended Protection High Milage has a very high GTL content along with a number of Mobil 1 oils especially their ESP and AFE lines. I’m sure there are other companies using GTLs too, Pennzoil just makes a point to advertise it.
Why would you think that? GTL derived Group III base stocks are chemically similar if not identical to any other Group I, II or III. Not like PAO. The difference comes in the VI and sulfur content, not molecular structure.
If I understand things correctly, mostly from watching Lubrication Explained, a PAO oil is basically pure paraffins. Does a lot of things great but has terrible additive solubility.
Oil out of the ground is a chemical soup of paraffins and a lot of other stuff. As oil is refined from crude -> group 1 -> 2 -> 3 it becomes more paraffinic. Keep the paraffins, toss out the other stuff, but the solubility goes down which is why you’ll see small amounts group 2 oils pop up in blends.
GTLs while starting off as natural product end up being highly paraffinic like a PAO. PAO performance on the cheap, awesome, but the solubility sucks. Something needs to be added to blend the additives in. That could be an Ester, or AN, it could be a dash of good old Group 2, or a blend but something needs to be added.
I'm not sure what you are saying there. I have a minor in Chemistry, but only that.
Group I, II and III are all the same, chemically. All Group III base stocks are hydrocracked and end up with a similar structure. PAO is non-polar and that is where the solubility issues arise. Yes a Group III would have less solubility due to less saturates but it isn't going to be like PAO. It would depend on the degree of hydrocracking too, there are other Group III base stocks other than GTL that have a similar VI and level of saturates. It's not restricted to GTL derived stocks and it's not due solely to the method of manufacturing.
But perhaps you know more.
Pennzoil Ultra Platinum uses a borate esters as its solubility agent if I recall correctly. Definitely uses the ester. And nothing besides gtl is listed as a base oil for it.
So , what has been the findings from those who are using the Pennzoil - made from Nat gas motor oils?
The over all idea of it sounds very good and I suspect (maybe way off?) that this made from Nat gas engine
oil may help to reduce or eliminate any build up in engines and possibly lead to cleaner engines with no need
for all of those engine flush products some try to push thru dramatic claims and advertisements.
I find the Pennzoil Ultra Platinum keeps my engines fairly clean. I got a ford fusion hybrid last year and cleaned it up with Valvoline Restore and Protect but have been running PUP since then.
It might very well simply be a marketing study they done finding out that people react 0.1% more favorbly if it says "with" rather than "from."
Everyone have their favorite oil, and to me that is PUP for regular usage vehicle (meaning not towing/tracking). I would pay the couple extra dollar to buy PUP over PP, and walk to work for a couple days to recoup that from gas expense
