Pennzoil Multi-Vehicle ATF
CA
My problem started in August of 2005 i took my 2004 Kia Optima Lx to the dealer for some problems they said the transmission needed to be flushed. I asked when it could be done and they said a month. I then called Jiffy Lube #2471 to see if the could do it. The guy said yes and said it would be $200 less then dealer. I took it in and the performed the service. (Kia's,Hyundai's and Mitsubishi require a SPIII (SP3) transmission fluid) Jiffy Lube put in Pennzoil Multi Vehicle ATF in. 4 months later i had my car towed into the dealer because there was a popping noise in car and their mechanic stated that the bearings in the transmission had worn out completly because the wrong fluid was put in. I went to jiffy lube and at first the guy was very helpful then a week later he is saying their not at fault and that they wont do anything. OF course the 10 year 100000 mile warrenty is voided for the transmission because i took it some where else. Now im stuck paying for a car i can't drive because i can't afford the $2000 to fix the transmission if anyone has any suggestions it would be appreciated my email is
http://www.jiffylubeproblems.com/Experiences151-175.htm
Pennzoil Multi-Vehicle is recommended for SPIII applications by Pennzoil.
Yikes!
Warranties don't get voided.
Bearings died because of what???? MFG defect or poor lubrication(hint incorrect ATF level)?
Now, if he fried the clutches or experienced poor shift quality(shudder)..... it would be more believeable. But, how many months of shudder do you put up with before going back to the so-called better OEM fluid?
And, IMO, Kia/Hyundai transmissions run hot, break easily, and just generally suck. I fried 2 Hyundai transmissions(one brand new, the other used rental) in
I do not understand these people that just walk away when the dealer says they won't fix the problem. There are clear dispute resolution procedures published by the MFG. Dont they even bother to read the manual?
When the dealer says "it was the non dealer service that caused the problem" do they really just say "oh" and walk away? The dealer has to proove is was the incorrect fluid that caused the problem.
Jeez.
Yep, they just walk away
But 1st, they tell the dealer that they serviced the transmission with the wrong ATF
Funny, since most transmissions don't require any service during the warranty period.
Then they go online and cry about it
That's why it's a huge risk to use anything other than the manufacturer certified fluid while the car is in warranty.
Even if the failure has nothing to do with the fluid, who needs the aggravation.
