I think that I am going to try this Pennzoil LL OW30 HD blend motor oil for my next interval. It seems this oil should do well with the cold winters here, having a pour point of -51*C (-60*F), and 17,847 CP at -40*C or *F.
I was reading the MSDS for this oil and I would like some help understanding it. It states that the oil has 25-35% lubricating base oils, and 45-55% synthetic base oils. Does this mean that the majority of the base oil is synthetic? I always thought that most blends had a fairly small percentage of the base being synthetic? Is this unique? Would the synthetic base oils be group III? This blend has a lower pour point than all of Pennzoil's group III "synthetic" oils.
I am assuming this oil has a similar additive package to the 15W40 LL (there's a UOA on this site for it), although the TBN for the 0W30 is lower (9 vs 12). What kind of intevals would be safe with this oil? Would it stand up to shearing due to the partially synthetic base?
The data sheet states that this oil has a viscosity of 11.8 CST at 100*C, which is about the same as the Pennzoil LL 10W30 (11.7 CST). Would it be okay to run this oil year round or would it be better to run heavier oil in the warmer months?
MSDS: 0W30 LL
http://www.pzlqs.com/MSDS/014/014380.pdf
Data Sheet: OW30 LL
http://www.pzlqs.com/Tech/Pdsheet/International/Canada/Pennzoil/English/EngineOils/pdf/LongLife0W30.pdf
Data Sheet: all other LL oils
http://www.pzlqs.com/Tech/Pdsheet/International/Canada/Pennzoil/English/EngineOils/pdf/LongLife.pdf
