Originally Posted By: CELICA_XX
I've been using the old Pennzoil Ultra 5w30 for 20,000 miles and I still use a quart per 3,000 miles.
In this case there is a question: what did you get using Pennzoil Ultra? What was the profit? Just fashion and because of everybody uses it?
Very often I read here: "I drive hard, so I need synthetic". Wrong. Mineral oil serves you just fine, could be even better. If your car has "cold" thermostat (85-90 C) and you are not living in Alaska, you just throw your money.
"Hot" thermostat (controlled by wire, about 100 C) has just BMW, AFAIK. May be some other "Germans" too. They need synthetic because engine oil temperature on idle could be up to 120C.
Why on idle? Because "German" controlled by wire thermostat increased the engine temperature on idle for ecology purposes. But if you press on a pedal and drive hard thermostat is opened and engine gets colder. See a paradox? Hard driving - less temperature, better oil condition. Traffic with a lot of idle kills oil, whereas driving, even hard, increase it's life.
One more thing against using synthetic "just because". This picture shows the difference between obsolete mineral and fancy synthetic. Pay attention what is inside of spoon. Same thing you have on your oil rings. And many-many synthetic oils are affected, especially Shell (Mobil1 is better, I mean safer).
Shell (i.e. Pennzoil) Ultra:
Mobil1:
Mobil1:
