So I had a GC for Amazon to burn, I decided to give these two products a try. Have you used either? What are your thoughts? I used both of them already. The coolant strip reported the same freeze/boil point as my hydrometer and the pH was in the "good" range.
The copper test for the brake fluid showed I was at 10ppm and the moisture tester (conductivity?) said I was 1% or less. I decided to do a quick and dirty reference check on the moisture tester by taking some virgin DOT3 from an unopened bottle (it's open now but oh well) and added a few drops of water and it pegged the meter.
So...good buy or bad buy?
Test Strips
Moisture Tester
Test Strips
Moisture Tester
