Originally Posted By: NovaMan
There is no mention of a float mode or turning off automatically in the instruction manual or on the packaging. However, there is also no mention of any danger in leaving the charger on the battery for long periods of time, and there is an LED that lights up when the battery is supposedly fully charged.
Edit: it also says it's a manual charger... maybe not what I had in mind then?
It certainly doesn't sound like a "smart charger" that you can leave plugged in continuously. The word "manual" usually implies that it is NOT automatic.
I think some battery maintainers just turn on/off (trickle) to keep the battery charged while others "read" the battery condition and continuously "float" a charge, so says the marketing gurus of battery chargers.
Unless you are an expert about battery charging, it is tough to believe all the marketing hype put out by some of the companies. But, here is a "probably biased" review that attempts to compare the "good" charger/maintainers vs. the lesser ones. It's educational, if nothing else.
http://www.batteryminders.com/batterycha...is-the-best.pdf
Explore the batteryminder site for more propaganda and then decide for yourself.
