163,000kms. Bought used in February 2025 with 138,000kms. Because the 2.0T comes with a fancy plastic engine cover you never get visual inspection of PCV hoses until the engine throws a code. The code in this case was P0171 (lean condition) and P0326/327 (knock). I was shocked to think how long this system was compromised before the code showed up, so I took a look at my 2017 ATS 2.0T, and the main three way hose was compromised already! So the answer is it can be compromised for YEARS before the code shows up. So check under your engine covers folks!
Spent a morning this weekend replacing the three PCV valves and two PCV hoses on my 2014 Cadillac ATS 2.0T.
You'll need fuel line disconnect tools to get the hose off the turbo inlet and off the main 12663027 valve if you aren't replacing it.
Used the following OEM PCV valves:
12663027
12655399
12655400
I used inexpensive aftermarket hoses from Amazon. I found them of high quality with dual o-rings in each connector, along with handy quick disconnects for easy future replacement.
https://www.amazon.ca/dp/B0C9JD543S
https://www.amazon.ca/dp/B0CBPYBBCF
12663027
12655399
12655400
