Okay here is what I did guys/gals.
I upgraded the power supply unit on a 4 year old Dell from the factory 305W to a 460W aftermarket midgrade unit. The reason was preparations to install an HD Card for possible Bluray capabilities. However, after I installed the power supply new information was found by me. Prior to the install my old readings showed that high performance GPUs were power thirsty from 350-450W+ requirements (ie Nvidia 8800+ & ATIs 4800) However, now I have started researching and found out the new stuff from NVIDIA (200s) and ATI (5400s)are incredibly power efficient with the power needs well below double digits! Plus they have the near 100% CPU offloading/acceleration making my old Pentium D usable for HD movies. I can put off the Core-i series or Duo a little bit longer then
Therefore, my tangent question is do power supplies internally vary their consumption? Or is the power supply always putting out the rated 460W? (I mean this similar in the way that a car's gasoline engine is not always putting out peak horsepower.) If it is then my belief is that I would be then wasting power equated by my electric bill. I can easily step down to a lower rated unit if need be.
