Parts Master WL610255X
ND
While searching for Champ PH10063XL filters, I was directed to a local shop which carries the Parts Master WL610255X which I'd never seen before.
It's shares a similar number as a Wix filter but is made by Champ Labs. It uses a synthetic blend media, silicon ADBV, and a yellow Hydrogenated Nitrile Butadiene Rubber (HNBR) gasket. The box says it is rated 99% at 20 microns(ISO 4548-12 Multipass). $9.64 after tax from Auto Value.
Looks like the ADBV is black - seen through the baseplate hole at 5 o'clock. Does it say the ADBV is silicone on the box? I doubt it is unless a burn test was done to prove it's actually silicone.
Looks like the ADBV is black (seen through the baseplate hole at 6 o'clock). Does it say the ADBV is silicone on the box? I doubt it is unless a burn test was done to prove it's actually silicone.
Says “Silicone” on Parts Master website and “synthetic silicone materials” on the box.
oooo a yellow gasket :D
Someone on here will do the burn test :sneaky:
I wonder why the E Core tube isn’t used. Other than that, it looks like another quality Champ Labs filter.
Not sure. I have some Champ PH10063XL (Jun and Sep 22 date codes) that are metal core/louver and some Champ PH2867XL that are E-Core but they both have an orange colored ADBV.
Those louvers look 100X better than the ones in a couple WIX filters I looked at Monday (don't worry, I was grabbing some Microgard Select Filters to replace the WIX I had to use this OCI). At least 1/3 of them were nearly-closed or closed completely in both filters I looked in. Something I never knew to look for or worry about until discovering BITOG.
I returned an AZ stp extended filter that looked similar. COO USA. Black gasket with silicone adbv. Not a fan of the louvers though.
