The down side with the wear metals measurement in a low cost UOA is that it can only detect particles no larger than around 5-7 microns. So if there is wear metal larger than that, they will not be seen in the UOA.
If the particle counts are much larger like seen in the Lake Speed video, than that means the oil has way more possible wear particles in it. Many "oil cleanliness vs engine wear" papers say that lots of wear can result from particles less than 20 microns. That is why the Lake Speed video showed that the bearings got damaged (and the engine even lost power on the dyno) when the oil wasn't filtered very well in the smaller micron range with the metal mesh filter.
