Gardz was designed for drywall repair, from damage occurring to it when paper was removed etc. It will solidify the surface, and lock down anything that's punky or loose. Keep in mind you do have to get anything that is obviously failing down. You apply the product, then do your spackling. Once the spackle work is done the next step would be to spot prime the spackle work with Gardz if paper is going up. [Wallpaper, that if you hold a business card to the back you can't see the writing through the front of it], or a good latex or oil primer if you plan on painting, or if you can see the business card through the paper.
Dermapaint, I googled the Gardz product and discovered a lot of banter about it. Some pros seem to be claiming that they are using Gardz INSTEAD of primer in many instances. Here's one link, if you care to waste some time: http://www.painttalk.com/f6/power-zinsser-gardz-12852/ ...............Comments??
And a specific question: In our kitchen with latex paint, I have a plaster repair about 2' diameter (Real plaster, water damaged). Old material was removed and he reskimmed it. The plasterer suggested priming it with water base Kilz 2, I "think".
What's your opinion about priming it before repaint. Thank you for sharing your expertise. Sorry going off topic.
