I could write a novel on this mechanics tale. Remember the "Clanking going on in the '98 LS400" post that was happening because mechanic #1
failed to tighten the cam tensioners after replacing them both. Well, after doing all that I got P1346 and P1351. Mechanic #2 said
the timing if off and he said it was off a tooth or two on both sides. He fixed that. Car always ran fine. Now about 30 miles later I
get another P1351. I said, it's just a fluke. Erased it and it came back in another 30 or so miles.
I woke up and thought to myself, why don't I recheck the timing myself? Watched a few youtubes and went for it. I have attached
some pics so you guys can verify the timing belt is on correctly.
Assuming timing belt is on correctly, my question is, "Where do I go from here?" Mechanic #1 and #2 are at a loss as of 8:30 am this morning.
As you can see in the last phone, it was a little tight turning the crank from up top with radiator in place.
