p0121 code - help
ottawa
Hi Everyone
I need help with a code my engine keeps throwing - p0121 - throttle position sensor.
1 month ago my car threw this code, but was driving fine, nothing out of the ordinary. We have a trip coming up so I decided to replace the throttle body and tps, didn't want an problems on the trip.
Two weeks the car was fine and now the code has come back - I have check the connections and the voltage on both TPS's everything is fine - I am stumped\
Car is a 2008 Nissan Versa - and driving fine - no idle stumble or accel issues.
Is there anything else I should check?
Thanks
Nick
Originally Posted By: Quest
should still be within new car power train warranty, no? Get dealership to look into this instead. Q.
+1 on the warranty service, if available. If not...
My Altima manual (w/Versa, YMMV) lists three conditions the code is thrown, and possible causes:
Code:
A) An excessively low or high voltage from the sensor is sent to the ECM.
* Harness or connectors (the TPS circuit is open or shorted)
* TPS
B) A high voltage from the sensor is sent to the ECM under light load driving condition.
* TPS
* Fuel Injector
* Camshaft position sensor
* Mass airflow sensor
C) A low voltage from the sensor is sent to the ECM under heavy load driving condition.
* Intake air leaks
* TPS
No luck with the warranty - still driving me nuts - I may need to bite the bullet and take er in.
