What is your opinions on this type of ammo? I do have some 9mm 124 gr. +P HST loaded in one magazine for a 5906 and an SD9. The other 2 magazines for each of these guns are loaded with HORNADY 135 gr. +P Critical Duty Flexlock and 124 gr. HYDRA-SHOK. Those are the only 9mm guns I have +P ammo in. I would only use +P ammo for personal defense, never target shooting.
All of my other guns are loaded with standard pressure ammo (9mm, .40 S&W, SIG .357, .357 Magnum).
I can't figure out why you've got magazines loaded with ammo that you haven't actually shot, or why you've got them loaded with all different kinds of ammo.
If you haven't verified that a particular ammo works flawlessly in your gun, with every magazine, then you shouldn't depend on that ammo for self defense. It's a poor idea to presume that it'll work. I like the 5906. Reliable, strong, accurate. My first gun. Carried it as part of my flight gear during Desert Storm. But despite its reliability, and the fact that it's handled every ammo I've loaded it with, I would not bet my life on that gun until I verified that the ammo worked properly.
What you've got here, is a bunch of magazines loaded for the range. Have fun.
Once you verify that they work, then load your gun for defense.
Right now, you're just guessing...and the stakes might be your life.
Finally, how well you shoot matters more than tiny performance differences in ammo. Pick a good ammo, verify function, and be done. Watching you obsess over ammo is like listening to a debate on whether Exxon 92 is as good as Sunoco 93, or should you go with the Shell nitrogen enriched? In the same car, the differences are minor, and all the while, the driver is what really matters...
