Originally Posted By: Chris142
The reason toyota went to a smaller filter 20+ years ago was to lessen start up wear. The small filter fills faster than the ph8a sized one they were using.
OK enough already. First of all, how is the filter positioned? If it is mounted up-right, how is is it going to empty? If it's mounted on the side of the block, AND the anti-drain-back valve is working right, how is it going to empty?
Cheap filters with bad ADBV often have start-up noise because they let the galleries slowly drain down. Good filters with known good ADBV seldom have this issue. Napa Gold/WIX fit nicely in this camp. Very quiet on start-up.
Secondly, this may be a function of synthetic oils. I've had start-up noises with Mobil 1 in a number of engines. Put an HDEO conventional oil in same engine, dead silent. Put a syn blend in same engine - dead silent.
Since I do not change my filters at the same time as I do the oil (to retain some residual AW properties from the existing oil). I can always tell what the oil is doing vs the filter. You have to separate the effects of filter and oil on start-up noises...
As far as oversizing, once the filter is full and IF the ADBV is working correctly, there is little difference in start-up flow. Actually, there may be better flow with the oversized filter and cold oil because the larger media area will pass cool thick oil (all oils are thick cold compared to op temp) more easily and not have to open the internal by-pass valve.
There are various schemes for oversizing like using hydraulic filters w/o internal by-passes for race engines, etc. Don't apply here. In this case you are likely getting better cold flow and more volume in the whole system. In addition, you can run the filter longer before plugging. So say 12,000 miles and oil changes at 6,000.
There is no downside to oversizing except cost and fitment. Been doing this for 40+ years and never had it lead to any of the points mentioned so far. Where does this stuff come from ...
