If you want oversized it is.
Here's the spec'd WIX (NAPA if you knock off the "5" in front)
Part Number: 51085
UPC Number: 765809510852
Principal Application: Chrysler/Dodge/Jeep Vehicles (91-06), Mitsubishi Eclipse (95-99); Caterpillar 3 Series Excavators, 9 Series Loaders
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.790
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=15/28
Burst Pressure-PSI: 365
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Here's the FL1A size from Wix
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Nominal Micro Rating: 19
Gasket Diameters
The PL30001 is the FL1A/51515/1515 equivalent.
