I have a 2003 Corolla and it has a filter that is about the size of 1/3 of a Coke can. Is there a larger filter that will fit this mount?
I'm not 100% sure, but i think you can use either a supertech 3614, or a Motorcraft FL-400s, if they will fit. I think thay all have the same thread and baseplate design, so it's just a matter of fit. But since your's is a newer car, probably still under warranty, then you'd want to stick with oem sizes or equivilants.quote:
Those are the fram/Supertech/STP model numbers. Vehicle references are a 2002 Tundra (3614) or a 12V 3.0L Taurus (3600, bigger). Id use a Motorcraft FL=400S personally. Well I do use one like I said. Its got Purolator Pure 1 filter element and a silicon ADBV and only $2.77 at walmart. Just double check to make sure the slightly larger gasket will fit on the flange.quote:
"You can fit a 3614 tundra filter or a 3600/FL-400S taurus filter on there, but Id wait until out of warranty."
The car has 135,000km on it, so warranty is not a problem. What are the 3600 and 3614 numbers? I normally use the Fram number (not the filter) as a cross-reference guide.
I totally agree!quote:
Originally posted by FL-400S:
.... A rubber flap and a spring loaded piece of metal with paper stuffed into a can is not the most precise and accurate piece of equipment anyway. I wouldnt be surprised if filters varied from one to the next significantly.
I assume you mean same diameter as the longer toyota filter. If you want 1 quart capacity, you need a Motorcraft FL-1A or fram PH8A. Those are some big filters with the same bypass, gasket, threads as the FL-400S/3600/3614. Toyota has a TRD filter for Tundra V8s that is a relabled Wix 51515 which is FL-1A sized. However, I tried to fit an FL-1A on both my tundra and my tercel and the can is just too big to thread on either. I think the FL-400S is probably your best bet if you have the length space available under the hood.quote:
The 3600 and 3614 are the same size as the longer Toyota filter. I want a LARGE (1 quart capacity) filter that has the same flange/threads/DBV as the small Toyota filter.
In replies, could you state what manufacturers numbers you are using, please. I have no idea what an "sdf-15" is.
