JHZR2
Staff member
Sometime back, maybe a year, maybe two, I replaced an existing GFCI with a new one. The old one was the wrong color and the face had a crack. It worked fine though.
The GFCI is directly fed from a panel, and on the load side of it is a conductor that is switched for our bathroom vent fan.
Shortly after replacing, we started seeing that the GFCI would occasionally trip only when we switched the fan off. Slowly it has been getting worse and worse, as in more often.
We decided we wanted the bath fan to have s light, so we ought and installed a Panasonic unit (amazingly silent), and ran a new switch loop so we could control the light and fan separate. So we have existing wiring -> GFCI outlet -> fan power on load side of GFCI -> junction box -> new fan -> new 14/3 switch loops -> common dual type switch.
So the only remaining item is the wire from the GFCI to the fan junction box. A good multimeter indicates no issues with or between the wires.
So my only guess is that these new gfcis are overly sensitive. But any ideas if that's common?? Anything else??
Thanks!!
Thanks!!
