Originally Posted By: FNFAL308
Originally Posted By: boraticus
Originally Posted By: TFB1
Originally Posted By: steve20
when the muffler starts glowing red-you are about to either burn a valve or throw a rod---roll the dice............
A glowing muffler likely indicates a lean fuel mixture and could cause a burned valve, as far as throwing the rod, maybe but not probable...
Not sure about glowing mufflers however, I've seen header pipes on all kinds of engines glow red in the dark with no observable ill effects.
YUP, I have as well.. Actually pretty cool to see..
Yeah a high HP engine can cherry the headers at WOT fairly quickly, also seen turbos that had a healthy glow after a hard run... Still I'd be a little worried about my mower if it's single digit horsepower engine were cherrying the muffler... Running at heavy throttle in tall grass could no doubt do so, but on average it should not happen...
