PS - They sell for about $269 for a push model and $400 for a self propelled.
Going green doesn't mean letting nature overtake your yard. The LEHR Propane-Powered Push Eco Mower helps you keep your yard--and the environment--pristine. Fueled by clean, green propane that won't contaminate ground water or soil, this innovative push mower includes a four-stroke engine that runs for over an hour on just one propane canister.
At a Glance:
* Powered by clean, green propane
* Robust rotary motor provides 5.3 ft.-lbs. torque
* 20" cutting width for tackling tough jobs
* Easy starts with innovative Twist 'n Go design
* Exceeds 2011 EPA emission standards; winner of the EPA Clean Air Excellence Award
LM139NPTwo-in-One Propane-Powered Push Eco Mower
The Eco Mower helps keep your yard--and the environment--pristine.
This versatile mower features a large 1.7-bushel capacity and rear bag and mulching capabilities.
The Eco Mower Tackles Tough Lawns with Ease
This robust propane-powered mower provides 5.3 ft.-lbs. of torque to tackle tough lawns with ease. It includes a full-crank, air-cooled four-cycle, OHV engine with a cast-iron sleeve cylinder, and it also features a 20-inch cutting width, easy single-lever height adjustments, large 1.7-bushel capacity, and rear bag and mulch capabilities. The 8-inch front wheels and 11-inch rear wheels are ball-bearing supported and offer easy maneuverability over uneven terrain. For further convenience, the easy-fold, quick-release handle allows for simple storage.
Powered by an easy-to-use 16.4-ounce propane canister that snaps into place, the Eco Mower starts quickly--simply Twist 'n Go. Its patented propane-fueled technology eliminates the need for mixing gas and oil and requires no choking or priming to start. For further convenience, propane canisters are widely available, and a single canister provides one full hour of run time.
This mower also eliminates the need for the winterizing, carburetor gum-up, and choking commonly associated with gas-powered mowers. With an engine that starts faster and runs cleaner, mowing the lawn won't be the hassle it once was.
Low Fuel and Maintenance Costs
The Propane-Powered Push Eco Mower boasts low fuel and maintenance costs. Standard 16.4-ounce propane canisters are economical and readily available at most hardware stores, sporting goods stores, drug stores, and other locations where lawn and garden products are sold. You'll cut down on expensive trips to the gas station and eliminate the risks associated with storing gasoline in or around your home. An added bonus, the steel propane canisters are 100% recyclable when empty.
To further cut costs, this durable eco mower is incredibly easy to maintain. It's backed by a three-year limited carburetor warranty and a two-year limited manufacturer's warranty.
Environmentally Friendly and EPA Approved
Winner of the EPA Clean Air Excellence Award, the Eco Mower exceeds 2011 EPA emission standards meant to reduce lawn equipment pollutants. When compared side by side with gasoline, propane is clearly the smarter choice. Propane not only helps keep harmful pollutants out of the air, but it is less expensive than gasoline, so it also helps keep your money in your pocket. What's more, 85% of propane used in the United States is produced domestically, which means propane-powered tools can help eliminate dependence on foreign oil and can help cut down on the waste associated with fuel spills.
In addition, propane contains no evaporative emissions and zero ozone-depleting hydrocarbons. It's a nontoxic substance that won't pollute ground water or soil, and it includes 97% fewer particulates and 96% fewer carcinogens than gasoline. A cleaner and greener alternative to traditional fuel, propane power is a great choice for your garden.
What's in the Box
HR LM139NP Propane-Powered Push Eco Mower, tool kit, and owner's manual.
Product Description
Lose your dependency on gasoline by switching to the power of propane. This rotary push mower uses standard 16.4 oz. propane cylinders that make fueling easy. You just twist one in and go. Engine: Air-cooled OHV 4-cycle, Engine Displacement (cc): 139, Gross Torque: 5.3 ft.-lbs., Drive: Push, Cutting Height (in.): 1 - 3, Cutting Styles: Rotary, Cutting Width (in.): 20, Bagger Volume (bushels): 1.7, Front Tire Size (in.): 8, Rear Tire Size (in.): 11
At a Glance:
What's in the Box
Product Description
