It would seem my transmission is overfilled from the hot mark on the dipstick by about 1/4 to 1/2 inch.
I'm not noticing any effects of this considering there are no bubbles on the dipstick and shifting is fine.
Last week I had it in the shop for an exhaust leak but when they were driving it into the garage the CV joint failed, so that had to be done as well.
What I suspect happened...
Transmission fluid leaked out when the old axle was removed. The mechanic topped up the fluid with what he thought was an amount equal to the leak amount... but actually overfilled.
What they tell me happened...
The mechanic never topped up the fluid given he swapped the axles so quick that hardly anything leaked out.
What reality tells me...
Coupla years ago the tranny was overfilled and I siphoned enough out to return it to a reasonably normal level. Why is it after this job that the level is now reading higher? That seems to point to the mechanic dumping in too much fluid and now telling me they didn't because they don't want the trouble of siphoning the excess out.
It seems like a case of my word against theirs.
