Original EcoGard S195 Synthetic Cut Open
Mahzurrah!
This filter is off my JD lawn tractor after one season of use. It’s an older EcoGard in full green splendor. As you can see the base plate differs a bit from most Premium Guard filters and it has a nitrile gasket. Can was pretty thick and took a bit to cut. Paint was excellent as well. Didn’t count the pleats but there were a lot of them and straight as an arrow. There was a small gap at the crimp seam, that was it.
I believe newer EcoGards are more in line with the rest of PG filters now. Newer stock has a black can with green/black label.
As expected it looked great. I have two of these currently in service, one on the JD tractor and one on the Mustang (I must point out both of which are GREEN 😛) with five more on deck I will continue to use with confidence.
Enjoy.
Enjoy.
man that is a pristine one.. that China production is usually slightly messy and maybe this filter is from one of the other non-AFI China factories PG uses or vice versa. Pleats are also tighter than usual PG.
See.. Look at the wider pleat spacing and fairly messy glue on these other Ecogard Syn Blends below. I really doubt that these are coming from the same China factory as your filter.
Too bad an American company can't produce products as good as this.
It's not that they can't. But paying workers in America a livable wage, they can't compete with China where they pay slave wages. Add in all the fees and environmental regulations and they can't compete on price.
They can produce good quality but then no one would buy the filters because they would be too expensive. It is our fault. We did it to ourselves.
