Original 426 Hemi questions
What about fuel?
Ive found non-ethanol fuel on the pump but its 90 octane, i know they were designed to run pump with the 10.25:1 but thinking 90 maybe too low.
Also they need leaded and thats MUCH harder to come by.
Reading around on the web has been less than conclusive if the additives actually do anything at all.
Pretty sure these cars NEED leaded for the valve seats. Not so much for the octane as they were designed to run on the pump gar of around 93. Fuel pointers would be great
https://www.redlineoil.com/lead-substitute
From your description the carbs are over filling because the needle valves are not sealing against the seats. This typically isn't something you need a new carb to fix. Sometimes the old carbs had brass floats that would corrode and get pin holes so they wouldn't float, but many times, you can tap on the side or top of the carb by the outlet with a small hammer or a wrench and get the needle and seat to unstick and start working.
Another thing he can try is to pinch off the rubber fuel line and let the thing run till it dies. This will make the floats drop. Then take the plyers off the fuel line and crank it till it starts.
The incoming fuel may push whatever is keeping the seat from sealing out.
I suspect that a rubber line is coming apart internally myself. Or someone forgot to put a fuel filter in line.
These carbs were completely rebuilt not long ago but im afraid they have sat probably 2-3 years with fuel in them. Dont think my dad used non-E fuel either. Think this may work?
I could try that if the car started lol. It almost did yesterday but we decided to stop after finding both carbs leaking.
Do you have an electric fuel pump? Most Carter style carbs can only take around 5 pounds max of fuel pressure.
Yes, good point. We had Carter carbs on a few of our antique boats, that were also retrofitted with electric pumps and we had in-line regulators to restrict the fuel pressure to 5psi.
I'll post pics when I get better ones.
I'm thinking a good Italian tune up would work with some non ethanol pump which is 90 here. Add a few gallons of some kind of leaded fuel,if I can find it ..anyone have suggestions for that?
All I can think of is VP from a race shop.
No Italian tune up on American hot rod . Go easy at first. You are sitting on some serious car value.
My automotive work partner buys his non ethanol fuel at the local small airport.
Do NOT replace those carbs with edelbrock garbage. Get a guy to help you! It likely needs a needle and seat and top gasket kit. I would do it on the car.
and ... don't start a fire!
These old classics are simple, but occasionally need some attention. As others have said don't go replacing those carbs with cheap junk. I haven't looked, but I imagine there should be some competent AFB Carb maintenance videos on Youtube. If you don't want to learn this simple task yourself, find someone who is familiar with them, and let them tune them up.
Its not that i dont want to learn carbs, is that i need to move the car 800 miles and its much easier to transport if it runs onto the transport. I plan to rebuild them, again because they rebuilt not long ago, and get the car AFR / dyno tuned for the elevation i live at.
Those afb carbs are very easy to fix. You can pull the top off without taking the carb off the engine. The floats and needles are in the top so once it's off everything is right there.
I would not goof with aftermarket carbs just yet as imo the jetting will be way to lean.
Those are Carter AFB’s correct?
My dad has two of them on top of his blown DeSoto 341 hemi :)
never even seen an original elephant in person, but i have watched nearly every episode of Graveyard Carz...
I know for a while he had a Valvoline partnership, and when Customers picked up their cars, he could be seen handing them a red Jug ( like Maxlife coloring) then telling them to make sure they get Diesel oil, I think 15w40... do with that information what you will... I could be remembering it wrong...
An early, all-original, ‘stripper’ Hemi car…basically a street legal race car. Wow.
In today’s market, that is worth, what, $3 million??
