First post - sorry for the length.
I have a self-built 351w in my home-built kit car cobra. Since I built it, there are no manufacture's recommendations on what oil to use. I have read a lot of the posts here. Some even say to post this in the race forum, but I'm going to try here first. The race forum seems like it is for all out racing.
I will provide as much information here as I can to help with recommendations.
350hp/350tq at the wheels.
Stock 1982 block 351w bored to .040 over.
Stock crank .020 under
Stock rods .020 under
Hypereutectic pistons, moly rings
Moroso 7qt oil pan with windage tray. Moroso pickup.
Standard volume oil pump.
Comp cams XR282RF retrofit cam, roller lifters with dogbone locators.
AFR 185 heads, 1.6 rockers, Airgap intake, Holley 670cfm carb.
180 degree thermostat. Coolant runs 190-195 degrees with the fan on.
WIX oil filter - 1/2 height - can't use the F1A filter due to size restriction.
I drive it on the weekends. Usually short trips in town, but occasionally across town, or rarely across the state. Once a year on a track for a day - 20 minute runs with 1 hr cool down times. 2-3 times per year down to the local 1/8 mile strip (completely warm) for up to 10 passes with 10+ minutes between passes. It will sit over the winter for 3-4 months without being started. I don't drive unless the ambient temp is above 50 degrees. I will pull the distributor and prime the pump with a drill each year before the first start. I never just start the car and drive it cold. I always start it, then let it sit for at least a minute or two (usually about 5) before driving.
I have been using Castrol GTX 10w30 and it seems to be doing ok. I have about 60 psi oil pressure when cold. It gradually decreases as the oil/engine warms up. When hot, I have 15psi pressure at idle, and about 40psi at 3000rpm. I would like to see a little higher psi at idle when hot.
I have read about some of the recommendations for oils on this forum, but to be honest, I don't understand all of them. I don't have cats, so higher zinc won't destroy them. I can get Valvoline VR1 locally, as well as Mobil 1, but I'm not sure if i need them. I can order anything if I need to (Summit, Jegs, etc)
So, the questions are:
1. Weight - would a 10w40 be better? Do they make 0w40 or 5w40? Would the 40 base oil increase the hot idle psi? Or, do I even need to increase the hot psi? OR, would a lighter weight oil be better? Would 0w20 or 5w20 increase protection to the bearings since they will flow thru the bearings easier? Or 5w30?
2. Additives - I've read some stuff about zinc. Should I use a high zinc oil (or a small amount of Lucas additive) since I don't have cats? I don't have a tappet cam, so is this still important?
3. Brand - I don't mind using the high dollar/hard to find/need to order online oil if I need to (Joe Gibbs, Royal Purple, Rotella, etc). I would prefer to just go down to the local store and pick it up. I will usually only change the oil once a year since I only drive 1500 miles (maximum) a year.
Thanks in advance. Again, sorry for the long post, I just want to get the best recommendations..
