I have a chevy express 1 ton with 14 bolt rear end. At 30k miles the rear end failed and an axle came out. I had the entire rear end rebuilt. Since then I have put another 40k miles on it. The rear end is loud when I am on the gas and absolutely quiet when I let off and coast or slow down.
I drained the diff oil and saw metal shavings on the magnet.
I have since changed the diff fluid from 70w90 to amsoil 75w140. the diff noise is about half as loud now.
what do you guys think I should do? are these metal shavings an indicator of bad things to come. Will the higher weight oil help?
thanks
thanks
