My 2013 Titan randomly started transmissionmitting some vibes into the cabin. Just turned 150,000 miles and it’s been nearly flawless. Until now it’s only needed 1 axle seal and 1 starter its entire life. I parked it for 2 days and then drove it again and the vibes were present. It was so strange to me I thought it might be a bad tire. Put a new set of Michelins on it. Road force was 10lbs or less for each tire. Same thing. Installed new U joints and lubed the slip yoke. No change. Not sure where to go from here.
The center support bearing seems to be the same as it’s always been. This truck like most BITOG vehicles is maintained to the highest standard. Just serviced the rear diff. Metal on the magnet was minimal. Amsoil Severe gear 75w140 every 30k. Transmission drain and fill every 15k.
The vibes seem to start around 40 mph and feel somewhat like an out of balance tire. Around 65 to 70 the actual ride of the truck is pretty nice on the hwy but you feel that steady vibe that’s very different from an out of balance tire. I don’t feel any vibes when accelerating.
Thanks for any feedback.
