Originally Posted By: GMorg
Whoo! Hoo! VersaTrak quietened things down immediately! I didn't even get through my first circle before the groan had gone. I tried the opposite direction and, same thing. RP Synchromax seems to have made a fine flush. But, Synchromax does not replace VersaTrak in the RDM of a 2005 Montana SV6! I don't think that I should start a separate thread, but there may be value in a subject heading that says, "Synchromax is NOT an alternative to VersaTrak."
#1 - glad to hear you have possibly taken care of this issue.
However, give it a little time to make sure it doesn't come back 1st( not trying to jinx you ). Sounds like you are having a real hard time with this vehicle and I would not jump the gun thinking it was fixed just yet. I believe you have said in the past even Versatrak only fixes the noise for a short time? Just sounds to me like something in there is not right( clutches, bearings,... )? Could just be fluid but it certainly should last longer than 25K before failing. Most GM AWD systems almost never call for the fluid to be changed, or at the least it is like 50-100K intervals, so if yours is killing the fluid so fast it makes me think something is wrong.
#2 - "IF" the groan stays away however give RP a call( ask for David Canitz - head of Tech Support ) and tell them it didn't work to replace Versatrak in your Montana's AWD system. I don't know enough about GM AWD systems to know which is which. I know RP Synchromax has been used successfully however in Saturn Vue AWD systems and The Chevy Equinox/Pontiac Torrent AWD systems. Both in the t-case and in the rear differential( or whatever they want to call it ). Not sure what, if anything, is different about your AWD system? But if Synchromax does not work in it they need to know.
RP is really good about NOT recommending their product where it does not work. Let them know for your application it does not appear to work. That will help them when making recommendations in the future. They "might" even reimburse you for the Synchromax seeing as you said they did recommend it to you?
