OVERKILL
$100 Site Donor 2021
Originally Posted By: Chris71
I suppose all you f**king know-it-alls are experts on oils now just because you can drive to Wal Mart or the Amsoil salesman's house and do your own oil changes? I tried to pass some info on to you and you automatically discredit it and why? "Well, I've never heard that or none of my friends have ever told me that" Go ahead and stick with your $10 a bottle oil. As a matter of fact, stick it, period!
Chris, I have a question for you, and I am not trying to be rude.
How many engines have you had apart in your life? How much experimenting (with tear downs) have you done on your OWN equipment?
I have SOME (albeit not as much as others) experience in this department with the engines in the cars in my signature.
I have the documented maintenance history for my Town Car from when it was NEW. I had the top-end off of it last year for a heads/cam/intake swap. The oil pan was off it in 1998 to be replaced. It current has 332,000Km on the stock shortblock. The bottom-end of that engine has never been touched.
It had Mobil 1 5w30 in it for 2 years starting in 1996 to 1998. When I moved to Ontario, my dad was having the garage change his oil and they began putting conventional in it and this continued until 2004.
When I acquired the car from him ('04), the PCV filter screen was plugged solid, causing excessive build-up of gases in the crankcase. I am sure this did not contribute positively to the condition of the inside of the engine.
This was evident when I pulled the intake and found what looked to be carbon/wax between the seem of the head/block in the lifter valley. There was no sludge, but there was some varnish in the valley.
There was no discernible wear on the cylinder walls (it has had a K&N panel filter since 1994), and the crosshatching was still visible (common with 302's).
In contrast, when I had my Mustang engine apart to do heads/cam/intake on it, I had put on over 90,000Km on various grades of Mobil 1 in it. I bought it with just over 200K on it, and pulled it apart at around the 300 mark. It was spotless.
It had never been apart either.
There was ZERO varnish, zero sludge, everything was CLEAN. It was much nicer inside than my Town Car engine, and with basically the same mileage.
These are not 3rd party examples. These are my own examples with my own equipment, that, by my own admission, I do drive extremely hard. The Mustang was drag-raced several times every season when it was together (it's in a new body right now that isn't done) and was on the rev-limiter many, MANY times.
5,000RPM clutch dumps on slicks, pulled to the red on an engine with 300K on it..... That's a fair deal of abuse. But very common use for one of these cars.
The Mustang community is a close-knit one. I have seen, and helped tear down engines of my friend's cars for various reasons, and the one thing that stands out is that the engines that were run on synthetic oil are cleaner and show less signs of wear. This isn't peering through the rocker cover, this is the engine coming apart for one reason or another and things being properly looked at.
It is different when you know the entire (or most of the) history of an engine and what oil has been in it, when it was changed...etc vs an engine that has come in and you are hearing from a customer as to how the engine was maintained and with what.....
A person who builds engines often has established a comfortable relationship with one brand and grade (or grades) of oil. They have had good luck with it, and so they will recommend it. And while this advice is based on experience, it is still far from perfect due to the operating conditions and maintenance of these engines being outside the realm of control.
And just to note: A person who listens to the builder as to what grade and what oil they should run in the engine is far more likely to adhere to that and the schedule than somebody who refuses to listen and wants to run THEIR choice and do it on their terms. It is often these people who will "exaggerate" how the engine was maintained when it fails and act shocked at what they see and then tell the builder that they were running a "good synthetic"........
I've posted up tear down pics on here as well, of two 302's; one poorly maintained on Dyno oil, one well maintained on Amsoil. The pictures speak for themselves. Feel free to look for them if you are interested.
